Re: 9n v belt replacement
Posted by Tim Daley(MI) on October 03, 2017 at 07:59:30 [URL] [DELETE] :
In Reply to: 9n v belt replacement posted by Torch on October 02, 2017 at 21:26:40:
Have you looked in our HOW-TO's under Electrical? SEE LINK for correct wiring setups.Original starters/generators/carbs/distributors/water pumps/hydraulic pumps/governors and more are all designed to be rebuilt over and over. You still need a starter. Did you mean generator? I don't understand. How did you determine your starter is shot? remove the crankshaft pulley??? Why??? Sounds like you still have the wrong setup -a mini-alternator? Where did you get your parts? Converting to 12 volt isn't the answer. If you insist on going over to the dark side, I'll buy your old starter and generator...my email is open.
