Re: oil pump
Posted by Carson (NCAL) on October 13, 2017 at 23:14:50 [URL] [DELETE] :
In Reply to: oil pump posted by AAm on October 13, 2017 at 21:37:41:
Yes you can get the pan off without splitting the tractor if we are talking about an N series tractor. I did one this spring. You need to support the tractor under the bell housing (clutch). Then the fun begins as you need to take the front end apart, remove the radiator etc. The pan can then be removed.
