Re: Thoughts on Gasoline?
Posted by Steve Reed (Mich) on October 16, 2017 at 08:31:54 [URL] [DELETE] :
In Reply to: Thoughts on Gasoline? posted by Farmer Dan on October 15, 2017 at 10:37:37:
I don't know if todays gas is any better. I found the Sunoco dealer in Brighton sells gas with no ethanol. They charge 40 to 50 cents a gallon more per gallon. I do know that with the no ethanol gas my float valve does not get eaten up. If I use ethanol gas I have to put new float valves in the carbs every two years. When I talked to Grand Valley tractor about this I was told that the ethanol is known to eat the material on the valve tip. I now look for all stainless steel float valves and also use the no ethanol gas. My tractors seem to run smoother and have a little more pep. Steve
