Re: Ford Aircraft engine
Posted by 36 coupe on October 25, 2017 at 21:11:49 [URL] [DELETE] :
In Reply to: Re: Ford Aircraft engine posted by SteveVa on October 25, 2017 at 15:41:52:
The water pumps and fan belt are missing.Exhaust manifolds are missing.Carb is backward.Heads are aluminum.The engine is from 1933 1936 era.The Ford fuel pump gave much trouble with weak fuel delivery.I always kept a new spare in the 36.You could buy a new pump in the Western Auto for 2 bucks.A leather shim could make a weak pump work longer.I can change Ford pum in the dark.I would never get into an air plane with a Ford fuel pump in it.
