Re: aftermarket led headlights on an 8N
Posted by K.LaRue-VA on November 02, 2017 at 19:55:19 [URL] [DELETE] :
In Reply to: aftermarket led headlights on an 8N posted by Billy Alexander on November 01, 2017 at 13:22:38:
The 4" would be too small for my taste.
Not sure if this picture will do it justice. A tree came down in the driveway last week. Had to get the logging chain and drag it out of the way with the 8N.
This is a 6 volt tractor putting out plenty of light. These are 6 volt h3 LED bulbs, in h3 conversion housings, that just barely fit inside the original headlight housings. I did have to bend the bulb terminals to the side and bolt wire terminals on with teeny tiny screws. the only downside is the h3 plastic lenses are flat across and will probably get scratched up driving thru brush.
The tail lights are also LED bulbs in standard 8N tail light housings.
