Re: 2n cooling issue
Posted by Charles (N.C.) on November 04, 2017 at 15:57:10 [URL] [DELETE] :
In Reply to: 2n cooling issue posted by Steve Frysinger on November 04, 2017 at 15:44:48:
Steve,,the pointed end with the wires should be about 3in. from the block.Sounds as if you have the thermostate backwards.Also put a plastic tie around the hose where the thermostate is so it won't move.
