Re: 2n cooling issue
Posted by Steve Frysingerf on November 04, 2017 at 18:14:39 [URL] [DELETE] :
In Reply to: Re: 2n cooling issue posted by Bruce(OR) on November 04, 2017 at 18:08:24:
Okay, makes sense. Does the water flow into the top or the bottom of the radiator? From what you said I'm guessing the top, which would explain hot water making it to the top of the radiator without the bottom hose ever warming up. So it sounds like my next step should be to flush the radiator (through the bottom hose) to make sure that pathway is clear.
Thanks!
Steve
