Re: Difference between fender mountd 8N to Ford 600 ?
Posted by Charles Krammin on November 07, 2017 at 22:06:36 [URL] [DELETE] :
In Reply to: Re: Difference between fender mountd 8N to Ford 600 ? posted by Tim Daley(MI) on November 05, 2017 at 05:57:09:
My original question related to "difference in fender mounts between N's and Ford 600". You posted a picture showing the stabilizer pin as about 1" difference front to back. I therfor deduced, but didn't reply as such, that the mower breakaway mount below the stabilize pin, for a Dearborn 14-15 mower, was also different, causing me to adjust the length of the breakaway. Problem solved, therfor no reply needed. Just answering puzzle created in post.
Thanks for posting the picture.
PS I also had to make longer lift extensions as the Ford 600 lifted higher. I also modified a pto male drive , from TSC, for a "fertizer spreader", from 7/8"X3/4" to 3/4"x 3/4", by machining. This shaft fits the 600 1 3/8" pto shaft. I now have a quick couplier and safety shield.
Thanks for your help. Mowed the roadside bank and a ditch bank. and things worked good.
I now have enough mower parts to malke another good one and some parts left over.
Charles Krammin
Hastings MI
