Re: 9N Starter Disengages When Engine Tries to Start
Posted by Jack - Iowa on November 11, 2017 at 08:06:24 [URL] [DELETE] :
In Reply to: Re: 9N Starter Disengages When Engine Tries to Start posted by Tony Sanchez [OR] on November 10, 2017 at 23:22:05:
IF you try the hand crank, be sure and hold the thumb against that first finger. That way if it backfires the handle slides out of your hand rather than trying to take your thumb off. In other words, lay your hand on the crank handle and wrap your fingers down and around. DO NOT PUT YOUR THUMB UNDER THE CRANK HANDLE.
Good Luck,
Jack
