Re: Coil or condenser
Posted by Dollar Bill on November 13, 2017 at 05:34:11 [URL] [DELETE] :
In Reply to: Coil or condenser posted by BeanStalk on November 12, 2017 at 18:20:25:
Weak or No Spark: Run a jumper across the ignition switch terminals and try it. If it starts, replace your ignition switch. Don't leave the ignition switch jumpered for long periods with engine off or you could fry the points and the coil. If it wasn't the ignition switch, check for voltage at the small wire on the coil. On a side mount, look closely at the wire coming from the coil to the distributor. This wire often gets damaged where it passes through the distributor housing.
