Re: Jubilee Hydraulics
Posted by mhb@ufe on November 14, 2017 at 09:20:56 [URL] [DELETE] :
In Reply to: Re: Jubilee Hydraulics posted by John on November 13, 2017 at 20:40:03:
That was well explained and should work for you as long as you have the round piston type hydraulic pump. If it has the square vane type pump it will not have a bleed screw on it. With the vane pump they will sometimes pick up the prime if you nose it down a steep bank. The vane pump is also the one people are referring to using air pressure to prime.
Mark
