Re: Shiftr boot myth debunked!
Posted by TheOldHokie on November 18, 2017 at 15:14:18 [URL] [DELETE] :
In Reply to: Re: Shiftr boot myth debunked! posted by JMOR on November 18, 2017 at 09:35:47:
It is empirical data and a conclusion. You can question the validity of the test and possibly the resulting conclusion but you can't question the measured results:
ZERO water passed through a bootless shifter subjected to a 5 minute direct stream of water sufficient to flood the entire tested area.
If you question the conclusion I'd like an explanation of the error in the test procedure.
I'm afraid my well might object to that last idea so someone else will have to run that iteration.-)
TOH
