Re: Fuel Cut Off Valve
Posted by clayton ingmire on November 19, 2017 at 18:10:20 [URL] [DELETE] :
In Reply to: Fuel Cut Off Valve posted by Tony Sanchez (OR) on November 19, 2017 at 17:55:37:
just a thought might be better to fix carb it is ether a bad or dirty needle and seat or is float setting is to high providing you don't have a bad or sinking float also check that the seat is tight in the carb it self just my two cents good luck
