Re: Gear Oil and Water
Posted by Jock(OR) on November 20, 2017 at 04:30:09 [URL] [DELETE] :
In Reply to: Gear Oil and Water posted by Tony Sanchez (OR) on November 16, 2017 at 19:44:06:
If you have something to attach to the 3-point, like an implement, it will provide the weight to help lower the lift arms. Then you can exercise the system, since it seems to be working better with use.
Good luck! I hope the system returns to normal with exercise.
