Re: 1950 8N Rear Two Seal Axle Bearing Lubrication
Posted by Dean on November 25, 2017 at 12:51:42 [URL] [DELETE] :
In Reply to: Re: 1950 8N Rear Two Seal Axle Bearing Lubrication posted by Rustyal on November 25, 2017 at 11:28:57:
The late design 8N/NAA rear axle bearing must be packed. It is not lubricated with rear axle oil unless the inner oil seal is leaking, in which case the brakes will be lubricated as well.
The outer seal is not an oil seal, but rather, a grease seal intended to help keep the bearing grease from the brakes.
Dean
