Re: Fuel Shut off valve leak -53 Jubilee
Posted by grizz on November 28, 2017 at 16:36:38 [URL] [DELETE] :
In Reply to: Fuel Shut off valve leak -53 Jubilee posted by Roadrunner on November 28, 2017 at 15:41:49:
have you tried to tighten the nut where the valve shaft goes through also if it has a sediment bowl could have a bad gasket if it is leaking that much dry it off and wait and feel around till you find it
