PTO doesn't rotate
Posted by Dave (CO) on December 02, 2017 at 19:05:34 [URL] [DELETE] :
A few months ago my hydraulics quit on my 52 8N. It seems the PTO shaft is not rotating in neutral or in any gear. I replaced the shaft assembly thinking it my be the problem, but the new assembly doesn't rotate either. Turning the PTO by hand, however, does lift hydraulics. The tractor runs fine otherwise with no strange noises or grinding sounds.
Any ideas what might be causing the PTO to not rotate?
