Re: How about this one
Posted by Kirk-NJ on December 04, 2017 at 04:34:19 [URL] [DELETE] :
In Reply to: How about this one posted by Ultradog MN on December 03, 2017 at 20:06:31:
The back half of a 9n/2n/8n with bolt right up to the jub tranny. Gasket will cover trans knoch out. Some of the ones I've seen were done with 8n rears so you wouldn't notice it as much. Throw a blank plate over the Jub pump and use the 8n pump. Sure you loose the live hydraulics but you get a running working tractor. Not sure how he has the hydraulic pump hooked in. Possibly use the jub rear and bolted trumpet/axles on. Would have to have a closer inspection. 8n are more compatible with the brake pedals.
Kirk
