Re: Magnetic Oil Pan Heaters
Posted by TheOldHokie on December 11, 2017 at 12:24:30 [URL] [DELETE] :
In Reply to: Re: Magnetic Oil Pan Heaters posted by Larry on December 11, 2017 at 12:06:07:
NEWS FLASH!!!
The viscosity curve of a typical multi-grade SAE 15W40 engine oil is nearly identical to mono-grade SAE 30 and you will see pretty much the same results when things get cold.
TOH
