Re: 1941 - 9N
Posted by D Baethge on December 16, 2017 at 22:05:51 [URL] [DELETE] :
In Reply to: 1941 - 9N posted by D Baethge on December 16, 2017 at 16:11:45:
Thank you for the input. I'm gonna check the weights and inside of the distributor. I have been adjusting the timing at high speed and get no resemblance of smooth operation. EI could be defective? That did not cross my mind. Last resort I will go back to points if needed. Tractor did not keep a steady smooth speed under load plowing with Points I seem to recall dad saying is why he changed to EI. He also said the distributor was wore out but I found no slop in it. You all gave me some things to check out further so I'm not at a dead end yet. Thanks again.
