Re: lift pin leaking question
Posted by Dollar Bill on December 21, 2017 at 04:59:24 [URL] [DELETE] :
In Reply to: lift pin leaking question posted by 2NTony on December 20, 2017 at 10:41:22:
You can tighten the nut through the PTO shaft but unlikely you could manipulate the cotter key.
Like Zane advised, differential comes out from the left side so you only need to remove the right side trumpet.
It's not a hard job but it is time consuming and heavy - I used a cherry picker to save my back.
