Re: Electronic ignition
Posted by R Geiger on January 01, 2018 at 12:28:41 [URL] [DELETE] :
In Reply to: Re: Electronic ignition posted by Nic on January 01, 2018 at 12:08:16:
Google is your friend, you will find what yo seek.
With it not running did you set the flywheel to 8 degrees before installing the dist? If so try setting it to 0 degrees like the manual says.
