Re: Electronic ignition
Posted by JMOR on January 01, 2018 at 16:00:07 [URL] [DELETE] :
In Reply to: Re: Electronic ignition posted by Nic on January 01, 2018 at 12:48:54:
6v modules & wiring are different for neg ground and positive ground. Next, "rotor pointing to #1", means physically to #1 cylinder or to #1 on distributor cap and is that distributor cap position actually wired to #1 cylinder? Are you doing this at TDC-compression stroke or TDC-exhaust......flywheel mark is same either way, but one will work & other win't.
