Re: 52 8N front grill latches
Posted by Mike D on January 02, 2018 at 11:20:30 [URL] [DELETE] :
In Reply to: Re: 52 8N front grill latches posted by Tim Daley(MI) on January 02, 2018 at 07:49:23:
After all of these years the holes are a little worn but the biggest issue is that the rods have worn down to nubs. I think I am going to try to cut the old rods off the list cling lever and tack weld a new longer rod on then cut it to the needed length. I just need to find the correct diameter metal rod to use for the post replacements.
