Re: 1952 6V Side Mount Resistor
Posted by Matthew on January 14, 2018 at 09:31:24 [URL] [DELETE] :
In Reply to: Re: 1952 6V Side Mount Resistor posted by Bruce (VA) on January 14, 2018 at 08:13:56:
Thanks for the information Bruce, I will be making the trip to work on it again here in a couple weeks and I will check all of the things that you have here and I will post my results. I do have the shop and owner's manuals and I did download JMOR's wiring diagram before I got started. I tried switching the wires on the coil because it showed the wire from the terminal block running to the negative side of the coil. I am definitely a newbie to all of this and I greatly appreciate that you all take the time to answer questions. Thank you!
