Re: 8N won't start after warm up
Posted by JMOR on January 18, 2018 at 09:55:16 [URL] [DELETE] :
In Reply to: 8N won't start after warm up posted by Scott McKinnon NC on January 17, 2018 at 17:38:07:
Since you said the words, "...I turn it off", not "it dies", I will go off in a different direction than the others. Suspecting a worn out low compression engine, I'll expect that if you pull start it that it will crank up and run fine. If yes, do a warm compression check.
