1940 9N starter relay question
Posted by Serge on January 22, 2018 at 18:44:29 [URL] [DELETE] :
Hi friends
on my 9n there is no click when trying to start the engine If I clean everything and still no clcik does it mean the relay have to be replace?
NOTE: also does the relay have something to do about keeping the engine running??
the fact the push starter switch is not working if I use some booster cable connect the + on the starter and + battery and the - at the - battery use the other end of the - touch the tractor frame. The engine turn and it's trying to start (I keep playing with the choke and play with the gas when it seems to start if I let go the - from the frame it does not keep runnig.
your help is always appreciated
Serge
