Re: 1940 9N starter relay question
Posted by Serge on January 23, 2018 at 16:28:45 [URL] [DELETE] :
In Reply to: Re: 1940 9N starter relay question posted by Tim Daley(MI) on January 23, 2018 at 13:57:47:
yes it was converted to 12 volts and always was working perfect her the temperature is very cold like -20c I had to replace the battery about 2 weeks again because it would not charge anymore when boosting it was always starting but always been hard to start I had to play with the chock all the time after starting it was ok since the temperature outside started to play one day +1c and the next day -2c would try but would not start anymore and with new battery the engine is turning good BUT AFTER TRYING MANY Many TIME no more click from the switch?????
today I did remove the switch and with my volts meter set it at resistor I do have continuity noise about 3.2 Ohms (is this a normal reading?) place everything back in place clean all wires to be sure I have good contact everywhere STILL DOES NOT WORK
should I get a new switch???
thanks
