Re: starter problems
Posted by Bruce (VA) on January 23, 2018 at 19:18:19 [URL] [DELETE] :
In Reply to: Re: starter problems posted by g ostby on January 23, 2018 at 17:58:23:
Really?
You do know that a weak battery will result in precisely the symptoms you are describing, right?
Or, you cold need a tune-up.
It works like this......the bendix engages the ring gear on the flywheel & turns the engine over. When the engine speed exceeds the design speed of the bendix (because the engine is running) it disengages. (and I can never remember what RPM that is)
What is happening in your engine is that 1 or 2 plugs fire, the engine momentarily exceeds the bendix disengage RPM.....and it disengages before you have all 4 firing.
If you want to tune it up, just ask; plenty of folks can walk you through that
But, if you would rather just replace parts w/o diagnosing the problem, then yes, replace the entire Bendix as described in the how-to's.
