Re: Napa # for points?
Posted by Rusty2N on February 04, 2018 at 14:28:12 [URL] [DELETE] :
In Reply to: Re: Napa # for points? posted by Bruce (VA) on February 04, 2018 at 14:12:46:
Thank you again, Bruce! Don't normally do NAPA but it is Sunday. Had 2 dist. The one in the tractor needed rebuilt. Other was a siezed up old dist. Was going to take it apart to get a shaft turned out. By the time I gave up trying to get the drive gear rivit out the shaft was turning pretty good!! No wobble! So pulled what guts I could get out the top and cleaned it as good as possible. Stabbed it in the tractor and she hasnt run this good since I've owned her. Points need replaced but knew that going into it!!! Thanks again!!
