Re: 8N rear wheel
Posted by Tim Daley(MI) on February 11, 2018 at 07:00:55 [URL] [DELETE] :
In Reply to: 8N rear wheel posted by jeff walker on February 11, 2018 at 00:02:41:
I concur with Kirk -they should interchange. It's not the rims/wheels though, it will be the center discs. The Ford 28" 8N center discs are completely round. The Ferguson center discs are scalloped-a good visual method to tell. Ford went to the scalloped centers later on the Hundred Series models, why, I don't know. All use the 8-hole bolt pattern. I'd measure them first if looking, both the OD and the bolt hole pattern. I can post a formula to measure bolt hole patterns with if you need...
