Re: Diagnosing overheating
Posted by Bruce (VA) on February 18, 2018 at 21:02:11 [URL] [DELETE] :
In Reply to: Diagnosing overheating posted by Tom on February 18, 2018 at 20:35:54:
The most common reason for it to ďover heatĒ is over filling the radiator. Only add enough fluid to cover the core. (check out tip # 24, below as well as tips 25 & 35) It is not actually over heating; it is just spewing out the excess water.
If the radiator is not overfilled, check for low coolant, a loose fan belt, debris in the radiator fins or a stuck thermostat. A bad water pump will usually squeak or leak. (If you ever have a water pump start leaking or making noise, replace it immediately. A water pump will come apart & launch the fan into the radiator.) And, unless you have a new/rebuilt water pump from a reputable source, it could have impeller erosion. The pump will turn, it wonít leak, but it isnít circulating water.
The fan belt should have 1/2" of flex at the mid-point; no more, no less.
Unless you have a pusher fan, blowing out the radiator from the engine side is always a good idea.
If none of that works, you may need to flush the radiator & block.
Get a can/bottle of cleaner from the parts store.
Remove the t-stat. Reconnect the hose.
Pour the cleaner in the radiator & run the tractor to operating temp.
Then, remove the bottom hose from the radiator, stuff a rag in the bottom radiator hose connection, & stick your garden hose in the top of the radiator. Turn the water on (reverse flush) & the water will flow into the radiator, then the block & out of the disconnected lower hose. Let it run until the water is clear. Then, check the radiator flow. Stick the hose in the top of the radiator; the water should flow out of the bottom w/o backing up in the filler neck. It should flow at 19.5 gallons a minute. Donít forget to put the t-stat back in correctly!
Use 50/50 anti-freeze & distilled water as your coolant. The anti-freeze contains rust inhibitors, pump lubricant & raises the boiling point of the coolant.
If you do need to get the radiator re-cored, make sure you get the flat fin industrial core. Automotive style cores will clog up w/ debris very quickly.
Message: To add a single image to your post, click here. To add multiple images to your post, click here. Optional Link URL : Link Title : Website Title Optional Image URL:
