Re: naa hydraulics
Posted by WayneIA on March 12, 2018 at 12:49:58 [URL] [DELETE] :
In Reply to: Re: naa hydraulics posted by Doug on March 12, 2018 at 12:15:54:
Sound like you replace the whole cylinder safety valve as an assembly, so it should be fine. The control valve runs in bushing which is in the cylinder casting.. A used cylinder assembly might be better, but it is also used, soooooo, take your chances. One other thing. Make sure you have a good gasket between the cylinder assembly and the lift chest, also the spacer gaskets under the two opposite mounting bolts.
Message: To add a single image to your post, click here. To add multiple images to your post, click here. Optional Link URL : Link Title : Website Title Optional Image URL:
