1940 Ford 9N starter switch ????
Posted by Serge on March 14, 2018 at 18:44:36 [URL] [DELETE] :
Hi to all my friends
still not able to find my problem I did get two new switch
I did remove it from the tractor and every time I try the new switch I can ear a small click and than no more if I connect by passing the switch it turn the starter
so let say if I join the 2 cables on one side of the switch and tuch the negative at the battery it does make the starter turning the engine
so by passing the switch work???
could it be possible that both switch would be defective or just not made for a 12 volts
this is the switch (Atlantic 1100-0975)
still have another problem and maybe both could be related together
if bypassing the switch the engine turn trying to start but as soon the engine start and I remove the negative cable to stop the starter from turning it stop immediately??? the same way when you turn your key off
