Re: Ford 8 n wont run
Posted by Jack - Iowa on March 31, 2018 at 07:49:20 [URL] [DELETE] :
In Reply to: Ford 8 n wont run posted by Mike pellow on March 26, 2018 at 07:29:58:
Not only does it require fire and fuel, it also requires AIR. Years ago, when plowing dry, dusty, soil I had a 9N act like you are describing when the oil in the air cleaner got packed with dirt. If you have been in a very dirty atmosphere, it's worth a check. Easy check is to pull the hose off of the carburetor intake.
Good Luck,
Jack
