Re: Radiator Leaks -Opinions
Posted by steveVa on March 31, 2018 at 12:52:02 [URL] [DELETE] :
In Reply to: Radiator Leaks -Opinions posted by Tim Daley(MI) on March 30, 2018 at 08:52:42:
Tractor is 34 years old. Has the radiator/cooling system been recently flushed out? If not I would flush it, use some stop leak in just water till the leaks stop. When you fill it with water use a gallon jug to see how many gallons it takes. Than when the leaks stop, drain half of the water and add antifreeze.
If tractor is their only one and livelihood for a business that is dependent on that one tractor, I would pull radiator and fix right. If a backup or hobby tractor, fix with stop leak or pepper...
Just my half a nickel...
