Re: Starting issue
Posted by Tim Daley(MI) on April 05, 2018 at 15:04:56 [URL] [DELETE] :
In Reply to: Starting issue posted by BrianS, NE on April 04, 2018 at 09:23:58:
HiYa Brian-
Is your sprayer 12 volts? I thought all sprayers were 12 volts nowadays, hard to find a 6 volt unit. Check the battery first as mentioned to see if it is drained. Did you notice any negative or no-charge scenario on the ammeter prior to? Next step would be the generator and voltage regulator -local starter shop can check all of the above.
