Re: 12v ign system voltage & resistance test?
Posted by Bruce (VA) on April 09, 2018 at 13:06:50 [URL] [DELETE] :
In Reply to: 12v ign system voltage & resistance test? posted by Rusty 2N on April 09, 2018 at 12:41:30:
12v coil? Should be 3 to 3.25 ohms internal resistance.
Alternator should be putting out 14.5 volts.
Yea, a bad condenser will cause pitting/metal transfer on the points, but the likely suspect for 'going through points' is cheap points. Use Wells, Bluestreak or Echlin.
See tips 66,67 & 68.
