Re: naa hydraulics
Posted by Doug on April 09, 2018 at 18:26:39 [URL] [DELETE] :
In Reply to: Re: naa hydraulics posted by TheOldHokie on April 09, 2018 at 06:40:32:
So I pulled the plug on the pump and put in a barbed fitting and ran clear ode to the fill under the seat. Oil had air in it and was pulsating. Not a nice steady low. I also borrowed a gauge and put that n place of the pipe plug on the center housing. It never came off zero. Not really sure what else to check. Or should I go ahead and rebuild the pump at this point. If I pull the pump and spin it by hand would I be able to tell if some of the valves are stuck?
