Re: 12v ign system voltage & resistance test?
Posted by Bob in KS on April 10, 2018 at 09:33:48 [URL] [DELETE] :
In Reply to: 12v ign system voltage & resistance test? posted by Rusty 2N on April 09, 2018 at 12:41:30:
"1950 8n side mount"
Since this is a side mount distributor which should have the round can coil, do yourself a favor and replace your 6 volt coil with a 12 volt - no external resistor required coil, such as NAPA IC14SB or equivalent.
This will operate directly off of 12 volt system and eliminate the extra resistor. Should save a lot of confusion.
I would also replace wire harness if wires are old and cracked.
-- post on coil to side of distributor for negative ground, + post to side of distributor for positive ground. Same points and condenser for 6 or 12 volt.
