Re: 12v ign system voltage & resistance test?
Posted by Bob in KS on April 10, 2018 at 11:38:07 [URL] [DELETE] :
In Reply to: Re: 12v ign system voltage & resistance test? posted by Rusty 2N on April 10, 2018 at 10:32:54:
"12v coil included"
Which 12 volt coil?? "12 volt- no external resistor required" (approx 3 ohms across + and - primary) or "12 volt - external resistor required" (approx 1 1/2 ohms across primary)
As indicated the second one requires resistor for 12 volts. It could be used without resistor on 6 volt system.
