Re: maintinence
Posted by Frank (WNY) on April 12, 2018 at 10:17:47 [URL] [DELETE] :
In Reply to: Re: maintinence posted by Tim Daley(MI) on April 11, 2018 at 18:11:08:
Tim, I am in the process of cleaning the parts that make up the hydraulic lift system. As I am looking reassembling the lift cover, pump and PTO, I was looking for some guidance and want to thank you for the document you provided in the How To section. I am making a spreadsheet to reference the torque values for all of the bolts. You said that 57 Ft-Lbs is used for the 7/16"-14 bolts to attach the lift cover. I believe that is also true for the PTO flange? I am looking for the bolt torque for the aluminum pump base to the bottom of the center housing. Is it the same? Also, how about the 7/16-20 bolts that attach the chambers to the aluminum pump base?
I also saw on another site that the round covers that go over the inspection holes should only got to 45 Ft-Lbs
If it would be easier, I could send the sheet to you to look over and possibly fill in other values? After I am done I would like to share this with everyone else.
