Re: Adjusting Arm Work
Posted by Kimberly on April 19, 2018 at 10:56:39 [URL] [DELETE] :
In Reply to: Re: Adjusting Arm Work posted by JMOR on April 19, 2018 at 10:41:39:
The adjusting arm is frozen; won't turn. The gear box at the top is free. I tried freeing it on the tractor but no go. I figured if I can get the adjuster off it will be easier and if it needs to be replaced then it needs to be removed. I didn't think it would be that hard to remove the bolt/pin at the bottom. I will continue to work on it and if need be call my BIL to come over and give me a hand.
