Re: dearborn 2 bottom
Posted by Tim Daley(MI) on April 19, 2018 at 17:50:29 [URL] [DELETE] :
In Reply to: Re: dearborn 2 bottom posted by Larry on April 19, 2018 at 15:47:38:
Hope you get it Larry. Plowing, then discing was the way it was done and still works fine. The N-Series Tractor was designed to pull a 2-bottom plow; 10, 12, or 14 inch, or a single 16" one-bottom plow. Your 3000 could pull a 3-bottom easy. You can't use a tiller on an N -not geared low enough. You'd need a Howard Rotovator, or some other step down transmission. Food for thought and good enough reason for the wife...
