Re: Steering Box
Posted by Charles(N.C.) on April 22, 2018 at 08:16:19 [URL] [DELETE] :
In Reply to: Re: Steering Box posted by Kimberly on April 19, 2018 at 11:48:29:
Kimberly,to the top of the steering arm there is a bolt.If you remove this you can put the grease zerk for applying the "cornhead grease (good stuff).To the left of the steering arms the adjusting screw and nut can be seen.After applying the grease I would adjust these first before trying to do any repairs.I would.The manual will cover this and as I recall you have to start with one side first.I can't comment much about which side because I'm not able to get to my book (outside)because I'm not able to get outside.Keep us posted on your progress.
