Re: Ford 3000 - Found the problem
Posted by K.LaRue-VA on April 24, 2018 at 13:43:17 [URL] [DELETE] :
In Reply to: Re: Ford 3000 - Found the problem posted by bkrsdoz on April 24, 2018 at 11:20:31:
Only problem with that is I've already used a hone to bore and fit oversize pistons. It has worked just fine for engines that turned a lot more RPM than this tractor engine will ever see. If a Sunnen hone can only be used for final fitting, they should not have made so many different medium and coarse stones for it. Going 40 over by hand is not going to be the most fun I ever had. No doubt, many of the things I do could be done easier and faster with more expensive equipment.
