Re: 4cyl. Ford 2000 with sos. Question
Posted by WayneIA on April 24, 2018 at 19:30:55 [URL] [DELETE] :
In Reply to: Re: 4cyl. Ford 2000 with sos. Question posted by SelectOSpeed on April 24, 2018 at 07:11:11:
Do you mean, will the engine turn the transmission when the engine is bolted up to the transmission. The answer is YES. There is no disconnect between the engine and the transmission. What SOS has described is after the transmission. going to the differential.And it would be advisable to have oil in the transmission when starting the engine.
