9N coil
Posted by Les Leach on April 26, 2018 at 15:14:31 [URL] [DELETE] :
I have been checking the ignition electrical on a 9N that has an alternator conversion to 12 volts. The primary ignition circuit steps down to six volts for the coil, through a resistor. Should I purchase a 12 volt coil and eliminate the resistor? Is there a link to a wring diagram?
Thanks for the information.
Les
