Re: Hydraulic pump leak?
Posted by JMOR on May 02, 2018 at 14:52:06 [URL] [DELETE] :
In Reply to: Re: Hydraulic pump leak? posted by JimWas on May 01, 2018 at 23:23:34:
these are the possible leak points. Another possibility is bent linkage which you can find by removing right side inspection port & observing and/or manually forcing linkage into the lift position.
