Re: Results with Draft control
Posted by HCooke on May 03, 2018 at 11:04:47 [URL] [DELETE] :
In Reply to: Results with Draft control posted by Kimberly on May 02, 2018 at 16:43:11:
When using draft control, do not lower the lever completely to the bottom of the quadrant or the plow will go too deep. As JMOR says, things may be out of adjustment. As you learned, your right hand can also be the draft control. I find using draft control is easier to make consistent furrows.
